I just bought a new HSF, so thought I'd share my findings using it.
I got the ARCTIC COOLING Freezer 7 Pro 92mm CPU Cooler from Newegg:http://www.newegg.com/Product/Produc...Tpk=35-186-134 for only $22, and I have to say it was worth every penny, and being so cheap you could probably pay in pennies rather easily ;).
I also added an intake fan to my case, but I already had 3 120mm fans blowing air through, so I don't think this made much difference, I only added the intake to try and get air going the way I wanted it to(through my filter). Anyhow I made a spread sheet with some numbers comparing the Freezer 7 Pro to the stock HSF that I was using before. Take a look, and consider one for yourself, especially if you have the stock cooler.
Conclusion:
The idle temp I had before is almost the same as what my load temps are now. This means I have a lot of room to overclock this CPU a lot more if I wanted to. Another great thing about it, was how easily it installed. I took out my stock HSF and put this one in in less than 5 minutes. It actually took longer getting the stock HSF out than it did putting this one in. I don't see the need to spend upwards of $50 on a HSF from another company, when this one does the job very very well at over half the price. I give it 10 out of 10!!!!
+ Reply to Thread
Results 1 to 2 of 2
11-30-2007, 03:12 PM #1N00b
- Join Date
- Oct 2007
- Posts
- 47
ARCTIC COOLING Freezer 7 Pro 92mm CPU Cooler - *REVIEW*
11-30-2007, 04:36 PM #2
Re: ARCTIC COOLING Freezer 7 Pro 92mm CPU Cooler - *REVIEW*
Front page!
http://www.geforce3d.net/index/node/93Q: What do you think about most during the day?
A: Women. They are a complete mystery.
~Stephen Hawking
Google+ Profile
Catch me on Steam - http://steamcommunity.com/id/g3d
Bookmarks
