+ Reply to Thread
Results 1 to 4 of 4
  1. #1
    Lightbulb Extreme PSU Calculator by:Antech
    Check it out. A calculator for determining the wattage you PC will need.
    http://www.extreme.outervision.com/PSUEngine
    Q: What do you think about most during the day?
    A: Women. They are a complete mystery.
    ~Stephen Hawking
    Google+ Profile
    Catch me on Steam - http://steamcommunity.com/id/g3d
  2. #2
    Intel Z68 FTW VW_Factor's Avatar
    Join Date
    Jun 2006
    Location
    Woodburn, Oregon
    Posts
    308
    Still have to pay to get the version that will show you amperes. :( Still neat that they did that though. Not many people actually care about that, and it really is the most important part of PSU selection.
    Which reminds me. I had to replace my PSU recently. The ol' Enermax bit the dust. It wouldnt stay on for much more than 30 seconds, even without a load on it.
    After reading quite a bit, I found the Tagan ITZ series to fit my needs perfectly.
  3. #3
    I'm going to look into making our own PSU calculator.
    ~Stephen Hawking
    Google+ Profile
  4. #4
    Join Date
    Jun 2006
    Location
    Woodburn, Oregon
    Posts
    308
    Quote Originally Posted by Uber_Tiny View Post
    Figure one if you can that will do the amperes. Thats really still a very important factor in PSU selection.
    I get tired of seeing all these multiple rail 12v PSUs. I shouldnt have a to get a 1200 watt PSU to get 30 amps on a rail yanno. Besides, if you dont use a rail, that extra current is wasted and doesnt go anywhere.
    Otherwise. After some research I found these Tagan ITZ series, with a "turbo" switch. Its not for the fans, but it connects the multiple 12v rails into one large one which is exactly what I was looking for.
    Thanks to Tagan for making a PSU that wasnt outrageously priced, uses sound engineering principles, and performs damn well too boot.
Bookmarks
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
Links monetized by VigLink
