This problem is caused by the following windows update:
KB920872
Size: 191 KB - 603 KB
This is a reliability update for Windows XP machines. Install this audio component update to prevent memory corruption issues which may cause an unstable state on a computer that is running Windows XP Service Pack 2. After you install this item, you may have to restart your computer.
More information for this update can be found at http://support.microsoft.com/kb/920872
Goto Add & Remove programes, Check Show Updates and unistall KB920872
your TS2 will return to normal.
You should be able to just remove your drivers for your audio device restart and reinstall the latest driver for that device instead of removing the update. If this does not work you will need to turn off allow updates and remove the latest update using the instructions above.
Thank You,
GeForce3D Team
